break-in oil ?
Old Mar 25, 2012 | 01:30 PM
saylorZ28's Avatar
Default break-in oil ?
how long should i leave it ??? a few hundred miles or or change it asap.
Old Mar 25, 2012 | 01:43 PM
BALLSS's Avatar
i change oil/filter after 1st 20 min "break in" cycle. Assemble lubricants, residue are in it
then 500 miles, 1500. 3000. Then every 3000
some feel less...it's your motor
Old Mar 25, 2012 | 02:37 PM
toomany's Avatar
X2
I usually run conventional oil for the first few oil changes before switching to a synthetic.
Old Mar 25, 2012 | 03:20 PM
Rob94hawk's Avatar
I used conventional and changed it 3 times. Shortly after 1st startup. Before the dyno. After the dyno. Then went to synthetic shortly after.
Old Mar 25, 2012 | 03:42 PM
saylorZ28's Avatar
ok well i wanted to know finally got to do my break-in and got it aligned front end back on and thaught i should but wasn't sure cause the break-in additive said different . i did not agree with that
Old Mar 25, 2012 | 03:53 PM
gjohnsonws6's Avatar
20 min,couple hundred miles or so,then 1500 then 3000 also
