LT1 Fuel Pressure check?
Old Mar 26, 2012 | 08:32 PM
BALLSS's Avatar
Default LT1 Fuel Pressure check?
is FP checked with vacumn line on or off and pluged.
I get 35 with vacumn hose connected and 42 off and pluged at idle
increases to 37 when driving and on gas
thx
Old Mar 26, 2012 | 08:34 PM
tt383lt1's Avatar
you always check fuel presure with the vacum disconected and i never plug the vacume line. but mine is 40 to 44 with no vacum on the regulator
Old Mar 26, 2012 | 08:35 PM
goldylocks's Avatar
with the vacuum line it simulates WOT which should be around 40-45 and idle is can be up to something like 8 or something psi below this. I'd say your pressure looks good
Old Mar 26, 2012 | 09:10 PM
F0x Slaughter's Avatar
Fuel Pressure 41 - 47 key on engine off.
Running at idle drop from 3 - 10 psi.
Old Mar 27, 2012 | 12:08 AM
BALLSS's Avatar
thx guys, I thought it was right
chasing a rich condition (high mv on o2 readings) and wanted to confirm FP as being in spec.
