need some help
Old Apr 4, 2012 | 12:56 PM
94T/A5.7LT1's Avatar
Default need some help
I hade to replace the hose that goes from the vent that on the valve cover to the throttle body. When i took the cover thats on top of the throttle body off and i found milky oil. I checked the valve covers and oil in the pan and it was all normal. I only found the milky stuff through the hose i replaced and the tb. Not sure if this normal but i doubt it. Any suggestions?
Old Apr 4, 2012 | 01:23 PM
WS Sick's Avatar
It is normal, the condensation will allways collect at the highest point in the motor, usually in the T/B or the valvecovers.
Old Apr 4, 2012 | 01:35 PM
Okay thank you, got a little worried.
