Meziere EWP users.......
Old Mar 25, 2004 | 07:33 PM
00Z-28-LT1's Avatar
Question Meziere EWP users.......
-how much trouble is it to install the heavy duty version? actually, how much cutting do you have to do to the fan shroud to install it?
-and do you think its worth the extra trouble for the heavy duty version or should i just get the standard version?
-thanx for any help
Old Mar 25, 2004 | 10:15 PM
Mike TexaSS's Avatar
8 Sec Tuner
Dude go HD i have one in my Impala SS and ir rocks. I never run hot even when hot lapped at the track. It also flows a hell of a lot more gallons of water.
Old Mar 25, 2004 | 11:52 PM
00Z-28-LT1's Avatar
im thinking the HD is the way to go so ill prolly order it tomorrow. by the way ive seen your Impala, its badass...
Old Mar 26, 2004 | 06:37 PM
DrewzZ's Avatar
i opted for the HD also.....you will have to cut aprox. 1/2 inch out of the fan support (no biggie) but it makes getting the fans in and out a lil more complicated, works great tho
Old Mar 27, 2004 | 08:06 PM
Rare96WS6's Avatar
I have the normal version on my TA and it never reads over 180 degrees
weather that is running at the track, highway, or sitting in 100 degree Texas heat. The fan shroud needed to be cut about two inches across by one inch deep.
Old Mar 28, 2004 | 02:39 AM
00Z-28-LT1's Avatar
since they both require cutting i got the HD........thanx for the help
Old Mar 28, 2004 | 11:39 PM
96-speed's Avatar
If I remember correctly the Meziere tech told me the regular one flowed ~35gph and the HD version was in the low 40. Not a huge difference IMO.
I might a little off on the numbers, or the tech might have been misinformed tho .
Ryan
