Back in the LTX game - time for a build
Things seem to have changed, not a lot, but a bit, in the last 8 years. It seems cam designs have improved, and the used market has gotten noticeably cheaper, which has been good to me as I have started to compile parts.
As she sits, it's stock sans a K&N intake and a GM Hurst Shifter with pro 5.0 stick. I have purchased the following:
LS1 driveshaft
Subframe connectors
STB
AS&M Monoblad
GTP Ported LT4 intake Manifold
GTP Ported LT4 heads (with all the valvetrain)
GM 847 cam
Mezz EWP
AS&M 1 3/4 mid lengths; I'll be running at least one cat, maybe two
SLP Dual/Dual with a cutout before the axle hump
I have injectors with a higher flow rate as well, maybe 30#r's but I can't remember now.
Here's where I am looking for feedback. I've always wanted the 847 cam. It sounds awesome, make great power, etc. I'm just thinking it's not the right cam for what I will use it for. I'd say it's 85% street, 15% strip. I'd love to hit 11's, but it's not a necessity. I'm also in MA, and I do the inspection thing the right way (I don't pay for stickers and I keep it all legal). I realize going from two cats to one is not allowed, but at least I'll have one.
Here's how I'm thinking about the 847 cam. For an 85% street car, the power band is probably wrong. Then, from an inspection perspective, they seem to focus on volume of sound, which should be pretty mild with th emid lengths and dual/dual, but also the idle quality. I know how this cam sounds, and it's going to raise eyebrows, and I know I can raise the idle, but that also could raise a few eyebrows.
This leaves me with getting another off the shelf cam or getting a custom one done, as I understand the newer cam designs can make similar or better power with a better idle than a 15 year old cam can. I DO have the flow sheets for the heads, which could be beneficial.
I'd love some input from you guys, like I said, it's been a while. If there's any other info you guys would want let me know, and I will provide.
Thanks!
Brian
They do two things in MA for inspection. Every year they do an OBDII plug in. Randomly they do a safety inspection. It works out to about every other year. The kicker is the shops can fail you simply for being too loud or being modified. Most have some level of tolerance on an older car for replacement part purposes, but if they want, they can fail you just because its modified. No sniffer.
On a setup like this, what kind of hp/tq will I pick up if I go 383? I have a high mile block I will be getting freshened up, so while it is out of the car I'm debating incurring the extra cost. Would the extra cubes change how someone like Lloyd grinds the cam?
Thanks guys!
Brian
Subframe connectors
STB
AS&M Monoblad
GM 847 cam
Mezz EWP
Ditch the cam and go custom LE cam.
Good luck!
