crankshaft hub.
Old Apr 14, 2012 | 10:30 PM
redhot lt-1's Avatar
Default crankshaft hub.
i`m looking for the gm part# for the crank hub on my 96 lt1 i stripped the bolt tread out and i don`t want to drill it and tap it. can you guys help.
Old Apr 14, 2012 | 11:01 PM
Rob94hawk's Avatar
You stripped the threads on one of the 3 on the hub? Or did you strip the threads in the crank snout?
Old Apr 14, 2012 | 11:18 PM
RamAir95TA's Avatar
Like Rob said it depends on which part you stripped. If you stripped the bolt hole for the pulley that's an easy fix. If you stripped the crank threads that's a different animal.
Old Apr 15, 2012 | 06:29 AM
Paul Bell's Avatar
That's MISTER MODERATOR
96-97 crankshaft hub: 12550097
Still available from GM, looks to be around 75 bux.
Old Apr 15, 2012 | 10:47 AM
96LT1355Z28's Avatar
PM sent
Old Apr 15, 2012 | 02:13 PM
thanks paul just what i need. i stripped one of the bolt 3 holes, i`d drill and tap it but it may throw the balance off so i`d rather replace it but thanks for your hhelp
