LT1 Flywheels
Old Apr 21, 2012 | 02:42 PM
Leedogg's Avatar
Default LT1 Flywheels
Okay I put a Street twin and aluminum flywheel in the TA last yr. Right off the bat it vibrated badly. Shoulda listened to the directions and had it balanced. So after a year of sitting on the trailer- i am finally getting it back out to have it balanced.
So the shop that is gonna balance the assembly. They wanted to know if I have the stock F/W, which i don't- I tossed it after putting in the Mcleod. I had assumed the flywheel was nuetral, since they internally balanced my 383's rotating assembly. but that was almost 10 yrs ago- and have long lost any paperwork from the build.
Now doing research i am reading that the stock motors are externally balance using a weight on the flywheel. There was a thin metal strip on the flywheel that came out of the car.
With out the stock flywheel, what am I to do? Am I screwed? scrap the whole motor(I'd part out the car at this point)?
Any Ideas?
Old Apr 21, 2012 | 04:28 PM
SS RRR's Avatar
Village Troll
If your rotating assy. is internally balanced they don't need any reference. They just need to zero balance the flywheel/pressure plate while the two are bolted together. That's it.
Old Apr 21, 2012 | 04:46 PM
Leedogg's Avatar
Thank Goodness- I was skeered for a minute there! Thanks a bunch.
Old Apr 21, 2012 | 11:57 PM
Konman93's Avatar
I used the RAM aluminum flywheel and love it, I was told that the aluminum flywheel's are a waste of money but I injoyed it. I never had a problem with any vibrations with my buildI agree with what SS said.
