quick question please help
Old Apr 24, 2012 | 08:48 PM
93v8clone's Avatar
Default quick question please help
friend is selling a garret gtx4294r turbo ,
turbine is a 82mm with a 1.01 t4 divided housing
compressor is a 94 mm exducer w/56 trim "70.3 inducer" w/ .60 a/r
would this supply a 383 s.r ????
Old Apr 24, 2012 | 09:10 PM
F0x Slaughter's Avatar
How many RPMS?
How much PSI?
A 383 at 6000rpm roughly needs 660cfm.
25psi - 1782cfm
20psi - 1558cfm
15psi - 1333cfm
10psi - 1108cfm.
Rough calculations to get you going.
Old Apr 24, 2012 | 09:20 PM
93v8clone's Avatar
7200 at 10 -15 p.s.i
Old Apr 24, 2012 | 09:45 PM
Well here do the Math.
CI x RPM x .5 x VE / 1768
So
383 x 7200 x .5 x 85% / 1768 = 662cfm
Now take the CFM and times it by the Pressure Ratio.
Pressure Ratio = PSI + 14.7 / 14.7
So 10 + 14.7 / 14.7 = 1.68
So 662 x 1.68 = 1112cfm.
Convert CFM to lbs/min
1112 * .0691 = 77lbs/min.
Looking at the compressor map. Not for 10 psi. It will not be efficient.
15 psi it won't be either its off the map.
They would work for a twin turbo setup.
