Lt1 t56 clutch
do resurface the flywheel. but not if its superbad and requiring a deep cut. it could cause problems with engagement.
roller pilot bearing is supposed to be the be"better" version.
also you can pack a **** load of grease behind it and use a rod the size of the pilot shaft pressed in quick and strong you'll see the bushing/bearing fly right out the crank.
