needs some advice
What should I do switch the timin cover over n the opit to 94 what about the cam, timing set is all that the same?
If so...
Use the 94 LT1 PCM and engine wireing harness on the 96 LT1 engine.
Leave the 96 timing cover without removing the crankshaft position sensor.
Leave the 96 vented opti spark dont worry about swaping the cam.
Use the 96 opti spark harness.
Use the 96 LT1 rubber hose that connects to the steam pipe tube at the front of the engine.
If im forgetting anything else, im sure someone will mention it.
Ty for clear the air for me! I was lost lol. Now what about vents for the opit where do I vent them to or what?
