27 spline 700r4 help
Old May 14, 2012 | 06:39 AM
jawsgt's Avatar
Default 27 spline 700r4 help
I have a buddy at work that has a built older rossler 700r4 complete with manual valve body that wants to sell it at a good price. what would be involved with swapping it into my 93 formula with a 4l60?
Old May 14, 2012 | 01:34 PM
96lt1m6's Avatar
No big deal..... change the speedometer cable hook up to your VSS and pull the tailshaft housing off to swap the drive and driven gears
Old May 14, 2012 | 01:42 PM
WS Sick's Avatar
Did you say the input shaft is 27 spline? need a converter to match that. Also the wiring is different, you'll notice the 93 has a round plug with 5 wires, the older 700s had a square plug 4 wire. Mostly its involving the lock-up.
Old May 14, 2012 | 01:53 PM
96lt1m6's Avatar
I just saw the 27spline deal hope you have a converter (stall) to go with that tranny cause you currently have a 30spline.....
