Manual Pedal Assembly Question
Old May 21, 2012 | 03:27 PM
1C3 MAN's Avatar
Default Manual Pedal Assembly Question
Hey guys i just need to know if there is any difference between the v6 fbody and the LT1 fbody manual pedal assembly's?
Because when i did by t56 swap i used a set i pulled out of a v6 car and they work fine exept the gas pedal seems to be set extremly low compaired to the clutch and brake and its making heel/toe shifting nearly impossible.
Old May 22, 2012 | 01:58 PM
1C3 MAN's Avatar
OKay since i can't seem to find the answere im looking for let me ask a new question.
Is there any way to move the gas pedal up closer to where the brake and clutch pedal sits?
I dont think i can just bend it because then it will over travel and put a ton of stress on the throttle cable right?
i know some people are using the spr pedals but do they move the gas pedal forward or jus make it wider?
