Changed the Optispark.....
Old Mar 29, 2004 | 06:06 PM
Slow TA's Avatar
Default Changed the Optispark.....
Now my car will not start and its backfiring and smoke is coming out of the intake when I do try to start it. I triple checked my plug wires and you can't really put the opti on wrong so whats the deal?
Old Mar 30, 2004 | 12:46 AM
TitanZ's Avatar
You can put the opti on wrong. It sounds like you may have put the dowl pin in the wrong slot. The opti has 3 slots the correct slot is marked. If I was you I would go back and check that out. I hope this helps.
Good luck
Dan
Old Mar 31, 2004 | 07:09 AM
Slow TA's Avatar
well I took it all apart yesterday and found out that I put it in the wrong hole. I guess when I tried to put it back in it moved around and went in a diffrent slot. works great now thanks for your help.
Old Mar 31, 2004 | 09:13 PM
mrhawk's Avatar
now we needs some runs with the bottle derick
