getting headers in place
Old Jun 4, 2012 | 11:46 AM
9D4Z28's Avatar
Default getting headers in place
in garage on lift right now. this is sent from ls1tech app on phone. doing my first header install on my 94 Z. I'm a college student this is my first big mod.
how the hell do i get the header in place? I've tried down through the top and up through the bottom. it seems like the oil filter is in the way. can i just take it off? please help.
Posted from LS1Tech.com App for Android
Old Jun 4, 2012 | 12:18 PM
VinR1's Avatar
What brand of headers and longtubes or mids?
Old Jun 4, 2012 | 12:23 PM
TravisMcGill2000's Avatar
I had to take the oil filter, starter, and steering arm off to get my headers on.
Old Jun 4, 2012 | 12:24 PM
I came up from the bottem on both sides.
Old Jun 4, 2012 | 12:36 PM
96TransAmboosted's Avatar
Have the car on stands as high as you can SAFELY work on it. I had the rear on ramps the front on stand.
Remove Oil Filter,Starter, Steering shaft
Note i also removed the spark plugs, the reason is sometimes the header flange will bump a plug and crack it or break it off completely.
I did both from bottom, and i started with the passenger side, you might or might not have to make a tiny dent in the header tube to clear the k member, it just depends on what headers you have and how good your mounts are.
Take your time are wedge them up in their.
Old Jun 4, 2012 | 12:43 PM
9D4Z28's Avatar
car on a lift. pacesetter headers LTs. im on driver side right now. the only thing in the way is the top half of the steering shaft. i already disconnected the bottom half.
Old Jun 4, 2012 | 01:15 PM
9D4Z28's Avatar
got it in just had to remove the filter along with the bottom half of steering shaft.
Old Jun 4, 2012 | 03:25 PM
9D4Z28's Avatar
how do i get around the oil dip stick when putting header in on passenger side?
Old Jun 4, 2012 | 04:00 PM
GMRACER13's Avatar
Pull the dipstick tube out.
Old Jun 4, 2012 | 04:15 PM
TimmyZ28's Avatar
When I did my headers, I took the large bolt out of one motor mount and loosened the other and I was able to rock the motor both ways and they fell in easy.
Old Jun 4, 2012 | 07:51 PM
pro94lt's Avatar
Honestly take out the steering shaft, the oil filter, dipstick tube, and i had to remove a motor mount. And if you dont drink this is something id advise getting a buzz before doing...
