Ground circuit 97 trans am
Old Jun 4, 2012 | 07:48 PM
DeanC1985's Avatar
Default Ground circuit 97 trans am
Where is the ground circuit located on a 1997 firehawk trans am my car is running horrible and its throwing code P1361 and this literally happened over night no symptoms
Old Jun 5, 2012 | 04:40 AM
RamAir95TA's Avatar
There is no ground "circuit" per se. The ignition coil wiring is probably shorted to ground (any metal surface) or 12v+. Look for breaks in the wiring around the ICM and back to the PCM. If you're handy with a multimeter you should be able to find it pretty easily, if that is the problem.
Old Jun 5, 2012 | 06:57 PM
DeanC1985's Avatar
Okay i just replaced the ICM just in case from one at the salvage yard and its still running the same so im guessing that it has to be a loose ground or its shorting out somewhere.
Old Jun 5, 2012 | 07:10 PM
DeanC1985's Avatar
I have an MSD ignition coil and MSD optispark distibutor ive heard those things go out pretty easy, does this sound like something that would cause that?
