im lost
Old Jun 5, 2012 | 11:27 AM
9D4Z28's Avatar
Default im lost
doing race header install and taking air pump out. is the big steel hose that runs in the u shape from the left to the right manifold underneath the engine the air hose? it connects to the air pump and i disconnected it.
does that need you come out? and how do I get out the way its bent around everything?
Posted from LS1Tech.com App for Android
Old Jun 5, 2012 | 11:31 AM
SS RRR's Avatar
Village Troll
It doesn't have to come out, no. I don't think it can come out unless you cut it up or lift the engine off the k-member.
Old Jun 5, 2012 | 11:33 AM
9D4Z28's Avatar
so it just sits there? it clutters and it was connected to the air pump? should i just cut it out?
Old Jun 5, 2012 | 11:39 AM
RamAir95TA's Avatar
It needs to be cut out. Even the FSM says that to remove it it must be cut under the timing cover.
Old Jun 5, 2012 | 11:42 AM
lethal bird's Avatar
Yep got to cut it.
Old Jun 5, 2012 | 11:56 AM
9D4Z28's Avatar
alright thanks
