padding to wedge between y pipe and frame
Posted from LS1Tech.com App for Android
Tweak the exhaust, add hangers to keep it away or maybe redo the engine mounts if they are soft and allowing too much movement.
Make the needed adjustments so that there is adequate clearance between you pipes and the chassis.
I wouldn't tell anyone that you wedged a piece of foam between your exhaust pipe and the frame of your car either..
You were using it ONLY to find the problem.. I was born yesterday, of course I believe you.
Go to Autozone and buy a universal hanger, stop trying to wedge things where they don't belong-- you're killing me, Smalls.
My car had it on there for 5 years and worked fine.. Kooks ory is bad about it.
