Running
Old Jun 9, 2012 | 08:45 PM
Mystery Bird's Avatar
Default Running
Finally got the new engine running and broke in today. Here is a video right after the 30 minute break-in. Will post video of initial startup later.
Old Jun 9, 2012 | 09:30 PM
lethal bird's Avatar
What cam does it have? Sounds nasty.
Old Jun 9, 2012 | 09:45 PM
Rob94hawk's Avatar
Congrats! Specs?
Old Jun 9, 2012 | 11:05 PM
3DFORMULA's Avatar
Sounds great.
Old Jun 10, 2012 | 06:52 AM
Forged 381 stroker:
SRP flat tops w/light wrist pins, matching JE rings, Forged Eagle crank and Rods, LE custom cam 242/248 58x lift, MB ported TFS heads, MB ported intake, 58mm TB, Hooker LT's, Dynaspark Opti, MSD wires, ARP hardware, ASP pullies...
Old Jun 10, 2012 | 09:27 AM
95mysticta's Avatar
Looks and sounds great! Always wondered what those hotrod valve covers would look on an lt1... any underhood pics with them on?
Old Jun 10, 2012 | 09:36 AM
3DFORMULA's Avatar
Yea, I'm digging the valvecovers
Old Jun 10, 2012 | 01:32 PM
transbird95's Avatar
Sounds great and looks amazing! What ET goal are you going for? I thought you said before the other engine went that you didn't want to have to put a bar in this car? Keep up the great work!
Old Jun 10, 2012 | 04:12 PM
Yeah, I didn't want to put the bar in but... I don't know what to expect for times, as long as it's not slower than my old SI setup. Just from the short break-in run doesn't feel like it will be slower. I'd be happy with low to mid 11's.
Old Jun 10, 2012 | 05:47 PM
Old Jun 11, 2012 | 02:45 PM
Jason94z's Avatar
http://www.youtube.com/watch?v=I-A8bq7sZBk
How did you get the hooker headers collectors up so high? Mine on a stock ride height are almost scraping the ground...
Old Jun 11, 2012 | 03:54 PM
I don't know, I just installed them. The cutout is the lowest point of the exhaust.
Old Jun 11, 2012 | 08:46 PM
Jason94z's Avatar
Mine are way lower. I have stock springs and I'm too scared to lower it!
Nice you lucked out
Old Sep 29, 2012 | 12:30 PM
lt1_2buku's Avatar
Hey mystery bird, have you gotten any track results with you setup?
Old Sep 29, 2012 | 02:36 PM
93 LT1 Vette's Avatar
Bet the neighbors are loving you, LOL. Birds chirping, quiet wind blowing, like a Corona commerical. Then rrrr, rap tap thumpity, thump. ******* birds gone flying for their lives, dogs barking. I love it.
Old Sep 29, 2012 | 03:59 PM
flyinZ's Avatar
Sounds good! What alt. relocation kit did you use?
Old Sep 30, 2012 | 06:28 PM
I just cut the stock one to fit
I went one time to log some data for WOT tuning. Not a good day, three runs. The posi gave out first run resulting in 1.9 60ft times, trans was slipping in 3rd, DA was high, and was pulling 3-4 degrees of timing because injectors are too small. Ran a best of 11.6 @118. I think after I get all bugs worked out should be a real low 11 maybe a 10.9 in perfect conditions @ around 121. Just put a new Eaton posi in and going to work on some 60ft times since trans is done on top end one more time before season ends so I can hit hard next year.
Old Sep 30, 2012 | 06:33 PM
lt1_2buku's Avatar
^^^ wow I would be happy with just the 11.6 what size injectors are you running? I wonder if I should have went bigger Im running 36lb ford injectors. Im curious cause we have very similar setups with the exact same cam. But 11.6 would be just quicker than what I was shooting for.
Old Sep 30, 2012 | 06:43 PM
Mattyfresh89's Avatar
sounds boss, great work! Wouldnt wanna run into you on the highway..
Old Sep 30, 2012 | 06:58 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Very very nice! LT1 done right!
Diggin that color too!
