Question
Old Jun 10, 2012 | 08:32 AM
BallerCamaro21's Avatar
Default Question
When I got the car the car rans good and the oil pressure was good and all so during the winter I took the motor out and replace all the gaskets and put a bigger cam in it and a new valve train. What would cause the oil pressure gauge to drop to almost zero but then goes to normal when the gas is applied?
P.s. 96 Trans am
Old Jun 10, 2012 | 08:51 AM
duh's Avatar
duh
Put a mechanical gauge on it and see if it's really dropping. If it is, either use a little thicker viscosity oil or rebuild your bottom end with tighter bearing clearances.
