anything else i can try??
It does shift at part throttle right?
Is this a 1-2 shift thing or 3-4?
If the pcm can command it to shift and it does shift at part throttle it seems unlikely to me that the pcm would fail only at WOT.
Tranny shops are VERY VERY quick to blindly blame pcms.
Does it shift if you let out of it a little?
You have told us nothing about the car, and next to nothing about the problem.
probably 11 years ago I had a similar problem when my car was near stock and the cause was a POS ignition "upgrade" that in the end helped nothing and hurt my wallet not only by being a waste of money but by causing me to throw parts at the car like you are now.
Based on your experience level though I would discourage you from trying a full shift kit install, if you want to buy one Transgo HD2 is the standard.
