Broken crank bolt and extractor
Old Jun 16, 2012 | 01:07 PM
Chevyguy358's Avatar
Default Broken crank bolt and extractor
The head of my crank bolt sheared off when my harmonic balancer decided to explode (stock), so I decided to drill and extract it. Well, I should have purchased a higher grade extractor because now I'm stuck with a broken extractor inside the snout of the crank along with the remainder of the bolt. I'm really hoping I don't have to tear the motor apart and have a machine shop extract it. Should I try to drill around the extractor and hopefully then remove that?
Old Jun 16, 2012 | 03:06 PM
LT1FirebirdSLP's Avatar
i would try to extract the extractor, then work back from there, with a higher grade extractor.
Old Jun 16, 2012 | 04:01 PM
FAD2BLK93's Avatar
X2...u dont really have many choices here. Either go for it or u will have to go to the machine shop. Good luck.
Old Jun 16, 2012 | 04:25 PM
tricked94camaro's Avatar
just had that happen to me with a exhaust bolt on a head. got too impatient and took the motor to a shop lol thankfully it was already out of the car!!
Old Jun 16, 2012 | 04:50 PM
blown97ss's Avatar
Samething happened to me. The bolt didn't break smooth so it had a couple places where I was able to get a chissel and tap the bolt loose until it was able to spin by hand.
Old Jun 16, 2012 | 10:26 PM
warriorcustoms's Avatar
Had that happen on my blazer I used a center punch to break up the hardened ez out Get the good square lookin ones **** those twisty ones Dont drill around it youll end up ****** the threads up ITS A BITCH but be patient & youll get it After the broken ones out drill it to the biggest square extractor The reverse drill bit kit ones work good too
