le2 build, help wanted
le2 =1600
roller rockers=150
push rods= 100
rocker studs = 50
timing cover gasket =10
head gaskets= 100
intake gasket=35
threadlock/cam lube/ oil /rtv = 50
timing gears and chain= 100
valve cover gaskets= 30
water pump gaskets = 5
lifters 100
tune = 400
all of these prices are approximate but let me know if i'm much off.
also if i'm missing something let me know.
any similar builds with le2 package dynoed?
Get the Felpro "conversion gasket set" it includes a lot of what you need including the oilpan gasket you left out.
You do not need cam lube.
You are very unlikely to need valvecover gaskets or lifters.
Far as $400 tune my junk is mailorder tuned.
When you figure out where to spend money appropriately you can buy better parts.
and 96mgr any suggestion on a cheap rocker that would work?
and on the gasket kit, i like that but would i benefit from a thinner head gasket meaning higher compression?
SA rockers don't belong on higher RPM motors. Especially since their NSA counterparts are far more stable.
A thinner head gasket would bump the compression - certainly not a bad thing.
Also itemizing your build like that gives you an unrealistic expectation of total cost. In other words expect it to cost 1.5x what you think it will once the incidentals are factored in.
do you think I was recommending the Felpro head gaskets? I wasn't.
From what I am reading I have to say the best thing you can buy yourself now is more time and delay this project.
BTW he recommended SA rockers for me as well.
