can you run an fitting for a type two power steering pump??
Old Jun 20, 2012 | 11:21 PM
tt383lt1's Avatar
Default can you run an fitting for a type two power steering pump??
im doing a relocation power steering pump on the driver lower side and i need 10an and 6 an fitting/ hosses. my question is can i run the normal type of fittings or do i have to get the kind that you have to get made/ crimped with a special tool??
Old Jun 21, 2012 | 01:03 AM
gjohnsonws6's Avatar
You can use aluminum on the return side but steel or stainless on the high side with ptfe hose. Regular ss an braid and aluminum fittings do not have a high enough pressure rating, seen people get away with it but personally I would not take the chance.
Old Jun 21, 2012 | 01:13 AM
tt383lt1's Avatar
i just bought a type two pump with an fittings. how would you plum it up to the stock rack???
would i buy special fittings to go to hard lines or would you get some an line crimped?
the an line crimp is what i ran on my old nitrous setup and it ran at 900psi
Old Jun 21, 2012 | 07:43 AM
If I had to do it I would get metric o ring flare to an/ jic adapters for the rack. Then use the ss re usable hose end and ptfe hose on the high side and regular an stuff for the return.
Old Jun 23, 2012 | 09:06 PM
tt383lt1's Avatar
do you know what size metric o ring fittings they are???
Old Jun 23, 2012 | 10:43 PM
jay7199's Avatar
can you post pics of your setup? im trying to do the same thing.
Old Jun 24, 2012 | 12:02 AM
tt383lt1's Avatar
http://www.summitracing.com/parts/AAF-ALL48250/
http://www.summitracing.com/parts/SUM-G3961/
http://www.ebay.com/itm/120935759914...84.m1497.l2649
this is the pump and bracket and pulley i bought. and im running the stock
resivor.
the fitting i came up with are
10 an female to 5/8" barb ( from the inlet pump to the resivor. low presure). im using the same size rubber hose as stock
6 an female to 3/8 barb ( from the rack out put to the resivor. low presure). im using the asme size rubber hose as stock
then two o ring flare fittings to a 6 an male. ( in and out of the rack).
then im getting a custom made 6 an hose with crimped fitting. ( from the pump the the rack. high presure).
that is all of the parts to do it but i need to find out what size the rack and pinion are inlets and outlets are. if i dont get a respond by tomorrow i will figure it out and post it up.
the only thing is you have to modify the bracket to work. not to hard for me to do. i just started on it today and i will post pics as i get more done
Old Jun 27, 2012 | 04:28 AM
tt383lt1's Avatar
figure i post this for people that are looking to do the swap i have $340 total in parts and its done today
parts are
stock resivor.
ps bracket $25 ( ebay)
rack fitting and hose fitting for stock lines $48 ( jegs) 14mm and 16mm
crank pulley and type 2 pump with pulley $184 ( summit)
v belt $10 ( orielly)
new rubber hose $20 ( ace hardware)
new high pressure braided 6 an hose $50 (local hydrolic shop)
ill post pics later tonight of the swap
the only thing i had to do is drill out the crankshaft pulley holes to match the hubs bolts. and i had to modify the bracket to work on the lt1 engine.
Old Jun 27, 2012 | 03:46 PM
FormulaJoe's Avatar
To be honest I would have ditched PS way before considering this. Especially as I'm sure this isn't your DD and is probably driven to the track on a trailer. + in your sig it says that it is a fully gutted car, why not just loose another couple pounds of stuff you really don't need and save that cash and labor for something else. Maybe I'm missing something, or maybe you just really like that PS..
Old Jun 27, 2012 | 06:27 PM
tt383lt1's Avatar
my car is a steet car. i had a flamming river rack on it for about two weeks and i hate the manual on the street. my front end comes up and down and the steering gets soft then hard when it does.
and i sold the manual rack and had some extra money on top of the conversion for more parts
