Oil question
Old Jun 22, 2012 | 06:31 PM
BallerCamaro21's Avatar
Default Oil question
Whatwouldcause the oil pressure to drop when the car is warm? The gauge is right because I hooks machianal gauge to it and then read the same and the rockers are not dry they are getting oil could the pump be bad?
Old Jun 22, 2012 | 06:56 PM
RamAir95TA's Avatar
Oil pumps rarely go bad and when they do it's usually the drive gear stripping and not the pump itself. What pressures are you actually seeing that worries you?
Also the physical properties of oil cause its viscosity to lower with temperature, i.e. a drop in pressure when it's hot and thin is normal.
Old Jun 23, 2012 | 08:01 PM
The oil pressure goes down to like 18 lbs when it is normal then it goes back up when the foot is on the gas
Old Jun 23, 2012 | 08:11 PM
RamAir95TA's Avatar
Nothing wrong with that whatsoever. The "check gauges" light doesn't come on until below 6psi.
Old Jun 23, 2012 | 08:25 PM
Ok thanx
