24x?
Old Jul 1, 2012 | 09:15 PM
lethal bird's Avatar
Default 24x?
Is there anyway to run a 2-step with the 24x conversion?
Old Jul 1, 2012 | 09:29 PM
94LTZ's Avatar
I know gregrob has, i believe he used the MSD ls1 style 2 step, seemed to work pretty well for him at the strip.
Old Jul 1, 2012 | 10:10 PM
SPRAYED Z's Avatar
I need to know this too
Old Jul 2, 2012 | 03:40 PM
SoxXpupPeT's Avatar
your best bet would be to contact Mike at EFI connections. Im sure hell have an answer for you. With that said. im sure any ls-1 2-step controller will work
Old Jul 2, 2012 | 06:42 PM
GMRACER13's Avatar
I use an MSD 2-Step part# 8733. Works perfectly.
Old Jul 5, 2012 | 01:49 PM
merim123's Avatar
a stock ls1 should work fine. if I recall, the 2 step plugs into the coil harnesses inline and then you need to provide it power and a ground. Should be just like wiring a ls1 car.
Old Jul 5, 2012 | 09:49 PM
95mysticta's Avatar
Keep us posted how you make out Mike. Down the road im going to eventually add a two step for the strip.
