Arp
Old Jul 2, 2012 | 09:56 PM
SPRAYED Z's Avatar
Default Arp
234-5602 instructions
my computer wont pull them up
thanks
Old Jul 3, 2012 | 12:07 AM
SPRAYED Z's Avatar
nobody can pull up the tq spec
Old Jul 3, 2012 | 05:06 PM
daddyoisback's Avatar
arp said to torque them to the specs that came with the kit i couldnt find the specs on there website. your part# is for the main studs with splayed caps?
Old Jul 3, 2012 | 06:42 PM
yellowlt1ta's Avatar
I have the same ones and I am holding the instructions in my hand right now.
Preload (torque) Recommendations:
(A) Torque valuse are based on 75% of the fasteners yield strength. use the manufacurers torque sequence but do not use the engine manufacturers torque specs. Torque the nuts to 70 ft lbs for arp moly assembly lubricant or torque to 85 ft lbs with 30wt motor oil.
Old Jul 3, 2012 | 11:36 PM
robsquikz28's Avatar
is that for all 4 bolts or just the two centers? I thought the outers will less?
but I could be mistaken
Old Jul 4, 2012 | 10:13 AM
thats all it says and they are for 4 bolt mains. I did them all like that
