383 lt1 or bigger
....594 hp for $3252 or 1203 hp stock 4.8 turbo 27#boost http://www.hotrod.com/techarticles/e...2/viewall.html
http://www.hotrod.com/techarticles/h...g_bang_theory/
My $4000+dollar NA 383's trans **** the bed nearly instantly, as does most factory **** with any power over stock..
Plan from The ground up. Take your rough estimate and triple it and you may still need a loan.
I had $4,000+ in a budget turbo ls1 f-car in just the trans and budget "turbo kit" ,mounts ,v-bands,couplers, radiator,fans,cooler,fuel system.. Still needed a real tune,a rear ,exhaust shop work,tires ,shocks, ect..
Its not cheap either way you go is my point, which one would benefit you more is anyone's guess.. GL
Check this thread out.
https://ls1tech.com/forums/forced-induction/1522770-fairmont-2-0-forged-lq4-s480-800whp-under-new-management.html
https://ls1tech.com/forums/forced-induction/1450736-my-turbo-build-5-3-t56-gt45.html
Go read the forced induction section if it couldn't be done people wouldn't be swapping out aes 370 for 5.3 . Again not trying to argue or start a **** storm.
so lets say you run a turbo'd 5.3 and it decides to let go one day while ur driving ur nicely waxed and polished up car down the highway ok ........well #1 you hope that after it chucks the rod it doesnt put a hole in the oil pan and dump oil on ur nice orange exhaust and light the whole damn car on fire (yes ive seen this before i watched a beautiful white SS burn down on the side of the highway).........2# you hope that when it does explode that the pieces that fly out the exhaust dont make it to the turbo and destroy that so you now have a 2nd paperweight........3. you now have to take the time or pay someone else to remove the junk and install the new one.......we know how much of a PITA it is to work on 4th gens.........
OR.........
instead of taking the hack solution to somthing you spend about $1800 and put forged rods and pistons in a stock LS1 and go haved fun.......no pulling the motor no worrying about it blowing up no extra motors hanging around........do it once and do it right.......
just my $.02
also in regards to your original ?..........joel is right budget and 700hp go together like making toast in the bathtub..........what id reccomend doing is build a good platform and enjoy it for a while........when you save up enough $$ to do ur turbo or supercharger you do it........also just personally for a motor that you want to be durable and last a long time long strokes and forced induction dont mix well.........the longer the stroke the higher the pin in the piston and the weaker it gets........if i were you id run just your normal 6" rod 3.75" 383 and stay away from going with the 3.875 396.........could even run a 5.85 rod if you want.....
It made almost 600 to the wheels and turbo was WAYYYY too small. Not to mention the WRONG camshaft.
With a 76mm on that same setup would have EASILY made 700 to the wheels.
Just because this is a second gen platform for some reason you guys want to make it hard to make power, it's a small block chebby man.
Here ya go
Have fun
http://www.lt1boost.net/home
