Miss Fire please help!!!
Old Jul 14, 2012 | 05:20 PM
ManMuchwano93z28's Avatar
Default Miss Fire please help!!!
a while back i blew the oil pump in my car but before that it was fine. so i changed the oil pump pick up cam gear new gaskets etc. but now my car is mis firing and i cant figure out why. i changed the spark plugs myslef to e3's. my dad said it could be a injector or a wire but im to sure. can you guys please help!
Old Jul 14, 2012 | 06:26 PM
96z28_lt1's Avatar
i'd check injectors spark plug wires all the fun stuff, has the opti been replaced recently?
Old Jul 15, 2012 | 03:49 PM
I tapped the injectors today still having that problem and I don't think the opti ever been changed
Old Jul 21, 2012 | 07:23 PM
Lgoldtop's Avatar
odds are good its the opti...
Old Jul 21, 2012 | 07:43 PM
FAD2BLK93's Avatar
See if u have a spark plug wire arcing. Open the hood when it gets dark and see if u have a light show. If u have a temp gun u can use it to narrow down what cylinder is not as hot as the others. Then u can change a plug, then a wire, then a compression check. And so on. Good Luck.
Old Jul 22, 2012 | 08:09 AM
96LT1355Z28's Avatar
Just curious how did you blow the oil pump? How long did it run withoout oil psi?
