93 T/A motor isues
Old Jul 14, 2012 | 10:19 PM
kyle.transam's Avatar
Default 93 T/A motor isues
So I have a 93 lt1 t/a, when I bought the car it ran fine. Now a few thousand miles later I've had the same issue twice. When I start the car it idles around 500 when it ran originally around 900. When I give it a bit of gas it starts to choke its self and starts to sputter and back fire from the intake. The first time I had the problem I was unable to find it.. after getting frustrated I gave up for the night went back the next day and it fired right away and no more problems. Now its back and I would really just like to fix it. I have no clue where to start look.
edit: it gave me a code 15, which is a low temp at engine coolant sensor.
Old Jul 14, 2012 | 10:51 PM
96z28_lt1's Avatar
not saying this is your problem but i had a problem some what similiar it was a timing problem, the rotor inside was timed off from the bearing.....
Old Jul 14, 2012 | 10:53 PM
Yeah, I've been told timing before, also have been told it could be a fault sensor. My service engine light is on and I hooked it up to a scanner. But sadly it wouldn't give me codes or allow me to clear them. Which really sucks...
Old Jul 14, 2012 | 11:20 PM
96lt1m6's Avatar
Check fuel pressure
Old Jul 15, 2012 | 12:14 AM
DisasterFormula's Avatar
Did you loctite the rotor screw? They like to back out.
Old Jul 15, 2012 | 12:40 AM
I've never done any real work to this car yet, so the I can't give you a definite answer but chances are the real answer is no.
If I were to take a video and upload it to youtube would any one maybe be able to help a little more?
Old Jul 15, 2012 | 12:42 AM
Certainly possible.
Old Jul 15, 2012 | 12:46 AM
I'll take a video tomorrow and upload it to youtube first thing in the morning.
Old Jul 15, 2012 | 03:05 AM
lt1-xjs's Avatar
Pulling codes is simple, just jump the a to b port with a wire. To clear them just disconnect the battery for 30 seconds. Try a search, pulling codes on 1993 Camaro.
Old Jul 15, 2012 | 08:23 PM
any other ideas?
Old Jul 15, 2012 | 10:30 PM
96lt1m6's Avatar
Did you check fuel pressure?
Old Jul 15, 2012 | 11:06 PM
No, just because I don't have the gauge on hand, tomorrow ill go and rent one so I can do it.
Old Jul 16, 2012 | 04:16 AM
lt1-xjs's Avatar
any other ideas?
Did you pull the codes ?
Old Jul 16, 2012 | 11:48 AM
Yes, i got a code 15. Found a wire to sensor had been broken so I fixed it. Cleared the codes and ran again and nothing came up.
Old Jul 16, 2012 | 11:51 AM
SS RRR's Avatar
Village Troll
Video sounds like classic case of loose opti rotor.
Old Jul 16, 2012 | 08:48 PM
I was waiting for someone to suggest cleaning the MAF lol.
