Constant brake sqeal?
Left the E-brake on for about a mile or so (Stop and go traffic) and now I have a constant metal on metal sound whenever I go forward (no noise in reverse).
Also the e-brake light does not come on when I pull the lever.
So what do you guys think?
Check the OD of the rotor to see if it is scraping against either the upper or lower pad.
If so, simple bend it a bit.
I've even dremeled casting pieces off of the OD of the rotor before.
So I'm not worried about the rotor I'm just gonna replace the pads and rotors and call it a day.
Unfortunately I won't have time to do the brake job until Sat :/
You think it's safe to drive? I have no problem braking it just sounds terrible...
Also why does it only make sound when going forward and not reverse?
It's pretty quick and easy to check.
While you are at it, look at your pads.
I can't see them being ruined in a mile, but I guess they could have been.
jack up the rear and put it in nuetral (chock the front wheels first).
rotate each wheel by hand to see if it is only one side that is affected.
