hp estimate
Old Jul 24, 2012 | 03:34 PM
jhobbins's Avatar
Default hp estimate
how much hp at the flywheel/wheels do you guys think im puttin out. if you need anymore info let me know
lt1 motor stock internals stock heads and cam
pro charger w/the 6# pulley
shorty headers
stock 3.23 rear end
2.5" Exhaust cutout, dumps just after headers.
Posted from LS1Tech.com App for Android
jhobbins's Avatar
the car is a 94 formula firebird
Old Jul 24, 2012 | 03:45 PM
jhobbins's Avatar
it also has msd ignition box 6a, ngk tr6 plugs, msd wires 8.5mm
Old Jul 24, 2012 | 04:47 PM
93 LT1 Vette's Avatar
Intercooler, pounds of boost, Mailorder tune, A4 or M6 ????
Old Jul 24, 2012 | 04:52 PM
defaultexistence's Avatar
TreeFiddie
Old Jul 24, 2012 | 04:58 PM
93M6Formula's Avatar
Neat ticking timebomb.
Old Jul 24, 2012 | 05:00 PM
In all seriousness, possibly 450 Crank/ 390 Wheels but it's hard to say. Please tell me this car is tuned.........
Old Jul 24, 2012 | 05:12 PM
jhobbins's Avatar
a4, 6lbs of boost, just bought the car, next on the parts list is mail order tune previous owner says its not tuned
Old Jul 24, 2012 | 05:17 PM
No intercooler or tune on just 6 pounds with 10.4 to 1 compression. Detonation will kill your motor quick especially in the summer heat. Have you data logged to see what kinda timing the computer is pulling out?
Old Jul 24, 2012 | 05:28 PM
jhobbins's Avatar
no i haven't. where can i get this done? this is my first muscle car so im new at this
Old Jul 24, 2012 | 05:38 PM
96capricemgr's Avatar
Even tuned this is not going to make much power, expect to be walked on by the average heads/cam car.
IMO the above estimate of 390rwhp is a wild pipedream I would be surprised if it made 360rwhp on as cast heads stock cam.
Far as addressing the tune where do you live?
Old Jul 24, 2012 | 05:40 PM
jhobbins's Avatar
rochester ny
Old Jul 24, 2012 | 07:36 PM
The cost to get it set up correctly could be several grand with intercooler piping and tune. It may be more cost effective to pull the blower and sell it. Take the cash and get some head work, cam and tune. or knock the boost down a bit, tune it and run it. 96 Caprice is from your neck of the woods and I'm sure he can hook you up with a quality tune.
Old Jul 24, 2012 | 07:45 PM
bufmatmuslepants's Avatar
3.23 gears has to put you over 400rwhp.
Old Jul 24, 2012 | 09:34 PM
LT1's Avatar
LT1
Agree, pull the s/c off. Your on borrowed time.
Have the bottom end built with lower compression and forged internals if you want reliabe power.
Old Jul 25, 2012 | 07:42 AM
jhobbins's Avatar
you guys really think id get fair value in return for the s/c?
Old Jul 25, 2012 | 07:50 AM
stevo9389's Avatar
expect to be lowballed to death for the s/c
tune it and and have a little fun while you save for a stronger build
Old Jul 25, 2012 | 09:18 AM
I would guess MAYBE $2.5K Tops depending on the condition but most likely $1,500. If you got that out of it, I would use that cash for a heads and cam package personally. You gotta realize that boosting that stock motor with no tune is just asking for trouble. I would definitely sell the supercharger unless you have the money to build a good forged motor (5K +).
Old Jul 25, 2012 | 09:55 AM
Puck's Avatar
Just tune it man.
6#s is fine on stock shortblock, just needs a tune. Later on you can get some head work, or if you wanna spend some cash rebuild it with new rods/pistons/rod bolts and cam it and up the boost.
I would not sell it if you already have it.
Old Jul 25, 2012 | 10:24 AM
**** all the noise, tune that bitch on a Dyno and stay within your bottomend and fueling capabilities it'll live longer than most of these nut swingers want to admit.. I wouldn't go over 8psi tops.. So stay with that 6# pulley ,pull the spark plugs and read them, make sure to put in some colder than stock NGK or autolights gapped at .035 and get to a tuner before you even build boost one more time ... I can't believe someone installed the SC and ran on no tune.... Then again it's not that hard to believe..
Does it have new injectors, fuel pump hotwire kit or fuel pump?
