24x ABS Question
Old Jul 28, 2012 | 08:02 PM
Shownomercy's Avatar
Man-Crush Warning
Default 24x ABS Question
1995 LT1, ABS will be removed and it will be a 24x conversion.
Can I yank the wheel speed sensors without any side effects?
I know the ABS/ASR lights will be on, but thats easy enough, more concerned with the LS1 pcm throwing a SES light.
Old Jul 28, 2012 | 11:13 PM
GMRACER13's Avatar
I have the 24x conversion and no ABS and my SES light didn't come on. Also, I took the gauge cluster apart and removed the bulbs for the ABS and BRAKE lights so my dash wouldn't be lit up like a Christmas tree.
Old Jul 29, 2012 | 02:15 PM
Man-Crush Warning
You did a full ABS delete with the sensors removed as well?
Old Jul 29, 2012 | 08:21 PM
GMRACER13's Avatar
Well the sensors are still in the front spindles but they aren't plugged in (removed the wiring) and the stock rear end was replaced with a 9" with no ABS sensor.
EDIT: Any codes related to the ABS system would need to be deleted in the tune. I don't remember asking the tuner to do that but he must have because my SES light does work but I do not have any codes related to ABS.
