Ticking on startup
Old Jul 29, 2012 | 11:15 PM
93Euphoria's Avatar
Default Ticking on startup
So I ordered my new radiator now theres an issue I kind of ignored for awhile because I heard is was normal on higher mileage engines. Could the ticking be a loose rocker? I took the valve covers off and tighten the rockers that had play. Then I started it up and it sounded like it was idling way too low and sounded uneven. Then I loosened them back up and now it runs fine but the ticking was still there. I made sure they had a little play in them. I dont know wether there too tight or too loose. It stopped making the ticking noise when I tightened them but the idle quality sounded like ****. I had no clue by adjusting rockers would change idle quality. I need to by myself a torque wrench but Any other advice to help solve the ticking?
Old Jul 30, 2012 | 12:17 AM
93Euphoria's Avatar
B.u.m.p
Old Jul 30, 2012 | 05:58 AM
gmstrong's Avatar
you can only adjust the valves when the nose is all the way down,its more then likely a lifter.
Old Jul 30, 2012 | 06:06 AM
tonskiguy's Avatar
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
