Theft Deterrent Relay Help
Old Aug 4, 2012 | 07:36 AM
Green94Maro's Avatar
Default Theft Deterrent Relay Help
Finally figured out what was keeping my Camaro from firing up. I ran a jumper wire from the purple wire to the yellow wire on the theft deterrent relay. I am now wondering what a permanent fix for this would be. Thank you
Old Aug 4, 2012 | 04:08 PM
great421's Avatar
There could be a # of things - The BRN wire at the VATS relay should have B+ with the Clutch pedal pushed in or (for the Auto crowd) with the Trans Range Switch in "Park" or "Neutral" - if that's OK, then with Key ON, the small YEL / BLK wire (again at that relay) should go to ground; i.e. - less than 5 Ohms or resistance from that connector to B-.
If those two things are OK, then I'd say replace your VATS relay...
I'd also suggest you check the terminal connection for the YEL / BLK wire and the relay, as if those two do not have good contact, then the relay will not trip.
(Ask me how I know!)
MORE INFO: Pages 8A-133-0 thru 18 of your GM Service Manual
Old Aug 5, 2012 | 07:53 AM
96LT1355Z28's Avatar
Often the porblem is with the ground for the TDR which is provided by the BCM. Post #6:
http://ltxtech.com/forums/showthread...ery-relocation
