LT1 died during burnout, now confused
Not tuning it was even dumber than buying the MSD opti. Don't drive it till you get it tuned after you get it fixed. The 95 pcm is so cheap and easy to play with, your cam alone cost about what it cost for the nicest tuning and logging software AND the nicest cable all combined and there is FREE tuning software, free logging software and cheaper cables can all be had.
I know cam companies have stupidity like "works with stock calibration" listed in catalogs but that is a LIE the stock cam benefits from reprogramming, it is critical witgh a larger aftermarket cam.
If you are willing to find and correct your mistakes you can see this through and enjoy your car. If you decide to get upset and pissy and defend your mistakes as a LOT of guys do this will be a long hard road for you.
Ignition "upgrades" are a complete waste on all but the most radical NA setups. Something like an MSD box is generally less reliable and some have reported them retarding timing a few degrees at high rpms which hurts power. I know on my car an Accel 300+ either does nothing or might actually slow the car down .05.
First thing I bought for my car was a $400 Jacobs ignition that in hindsight did nothing but cause problems. This is not a 70s vehicle, by 96 they were targeting a 100K mile tuneup interval and emissions standards were ever stricter so the ignition systems got very good.
Not perfect but good enough that for an NA setup trying to upgrade is almost always wasted money.
The specs for the sensor and several other opti related parts are for some reason jealously guarded secrets. And from what I've heard, Mitsubishi no longer makes the pickup, and I want to say acdelco no longer produces optis. What's out there in the stock piles is all that's left.
