Ta at the track first time tom!!
Old Aug 9, 2012 | 06:01 PM
Luke1996ta's Avatar
Default Ta at the track first time tom!!
Well after all the time I put into the car finally goin to the track tom. Whats your best guess with time. 355 with le lt4 heads and ported intake 30lb injectors 306 cam and mt radials subframe connectors lower control arms and panhard bar and 411 gears through m6
Old Aug 9, 2012 | 06:41 PM
Dave357LT1's Avatar
12.8 @112 1.9 60'
Old Aug 9, 2012 | 07:37 PM
93 LT1 Vette's Avatar
12.2 116 on DR's
Old Aug 9, 2012 | 07:45 PM
96lt1m6's Avatar
Depending on your driving skills, traction and your DA
1.7 60'
12.1
114
Old Aug 9, 2012 | 08:06 PM
Luke1996ta's Avatar
Yes 265/40/18 mt radial and I would say I'm a pretty good driver.
Old Aug 10, 2012 | 07:32 AM
Mystery Bird's Avatar
First time? 12.4-12.6 @ 110-112
Old Aug 10, 2012 | 07:42 AM
Luke1996ta's Avatar
Not first time but first time with this car.
Old Aug 10, 2012 | 07:51 AM
bufmatmuslepants's Avatar
4.10s with drag radials in a 10 bolt? R/T .658 and then boom 10 bolt
Old Aug 10, 2012 | 08:23 AM
96lt1m6's Avatar
I drove my 4.10s around for roughly 2 months went to the track 2 times and 1 time on DRs and that was it 2 1/4 teeth were missing on the ring gear now I will not have that problem ever again.......8.8 is ready!!!!!!!
Old Aug 10, 2012 | 08:43 AM
transbird95's Avatar
Have someone take a pic of your face when you look at the first slip. Always my favorite part
Good luck and have fun!
Old Aug 10, 2012 | 10:03 AM
lt1-xjs's Avatar
I would expect at least mid 11's.
Old Aug 10, 2012 | 10:12 AM
turtle93's Avatar
Good hook and 10 bolt will brake but if not 12.2 @116
Old Aug 10, 2012 | 10:23 AM
Luke1996ta's Avatar
Yes ten bolt haha and I do plan on launching the last pass of the day I just wanna c
What is does when I kinda roll out first. But you find the weakest part when everything is already built so kinda expecting something to break.
Old Aug 10, 2012 | 12:02 PM
lt1-xjs's Avatar
It's kinda pointless not to give it hell at the track.
Old Aug 10, 2012 | 12:46 PM
nomoneyz's Avatar
If your not going to go all out on it since your still with the 10bolt. I'll say 12.6-12.9 @ 114+.
Launch that **** and wait for the boom. May get lucky and hit bottom twelves or high elevens.
Old Aug 10, 2012 | 01:03 PM
If they were just ET streets and not radials you'd be safer, but the radial offers no sidewall give and hooks like a ****
Old Aug 10, 2012 | 01:24 PM
Luke1996ta's Avatar
I'm going to give her hell just not first pass I have to drive 2 hrs away so not going to try and break it first pass
Old Aug 10, 2012 | 01:25 PM
Luke1996ta's Avatar
They are et streets
Old Aug 10, 2012 | 01:58 PM
stumprrp's Avatar
Full weight? My guess if so is 12.50 @ 114 with a 2.0 sixty
Old Aug 10, 2012 | 02:41 PM
trilkb's Avatar
For some reason its always a look of "**** my life, that money wasnt worth it"
then you get home and DA correct it to make yourself feel better, and hypothetically lower your 60' lol.
CC306 with ported heads should be good for low low 12's to high 11's. But honestly, just have fun. Once you start not having fun is when it gets ugly. You could see anywhere from high 11's to low 13's.
