need info on the 94 vette??
Old Apr 5, 2004 | 01:13 AM
TSAEB's Avatar
Default need info on the 94 vette??
Mylil cus just got a 94 automatic corvette...he doesnt know anything about it...can someone give me as much info on this car...even free mods would help....thanks
Old Apr 5, 2004 | 01:32 AM
Vendetta's Avatar
you mean info that's different from an f-body, or just info in general?
Old Apr 5, 2004 | 03:53 PM
TSAEB's Avatar
Just info on the car in general...or should i go to a certain forum.
Old Apr 5, 2004 | 04:00 PM
Vendetta's Avatar
Well I'm not positive about this, but I'm pretty sure the 'Vettes have IRS, which means no solid 10-bolt to break. That gives you a pretty good platform to start off with. Start with a catback, some headers, and an intake system.. once you get past that, look at some suspension (depending on whether he wants to auto-x or drag) goodies and possibly a cam and heads.
LT1tech.com has an LT1 Y-Body section, but unfortunately the forum isn't very active.
Old Apr 5, 2004 | 11:27 PM
TSAEB's Avatar
i read they have reall small gears in the rear end like 2.7's something or around there...so if u say the rear end is pretty good how about some 3.73's with a stall...will that rear end take it. Also it has the lt1 motor right....so i could do about 2 free mods....thanks man...oh am i correct though.
Old Apr 5, 2004 | 11:43 PM
94Formula/TA's Avatar
I love this planet but the free mods start with a plasma cutter and the collector on the Y-pipe. Damn emissions
Oh well, you can bypass the coolant through the throttle body, move the IAC to the front of the intake, and a 160* stat is about $10 away from being free.
Old Apr 6, 2004 | 12:16 AM
DietCoke's Avatar
You-d be hard-pressed to find longtubes for a C4, so some good shortys would be a good start. The vette intake is terrible, a good CAI/ram intake does wonders for them. Rear end (dana) is pretty strong, some gears wouldn't hurt.
Old Apr 6, 2004 | 12:20 AM
Vendetta's Avatar
Yeah, wasn't sure about the rear. Go with some DRs too, then.
Yes, it does have the LT1 motor.
Old Apr 6, 2004 | 12:25 AM
TSAEB's Avatar
shoot Im going to have some good info for my lil cus...I guess Ill start on his car this weekend...94forumata can u explain a little more on the collector thing...but thanks ya.
Old Apr 6, 2004 | 12:29 AM
TSAEB's Avatar
oh and im ashamed to ask but what does "iac" stand for.
It was a joke about cutting the exhaust off before the cat . Actually I think its IAT, buts its the intake air temperature sensor. It's prone to heat soak because it's placed too close to the engine. I believe the corvettes have a straight intake tract over the radiator so if you locate it past that point it will give a better reading.
Old Apr 6, 2004 | 02:12 AM
Mad-Mic's Avatar
Thumbs up
sup fella's.
check out
http://www.corvetteactioncenter.com
http://www.corvetteforum.com
http://www.corvettekillstories.com
you can find all the info you need on those forums.
with the cheap mods and a set of muffler eliminators he car could run high 12's or low 13's very easily! mid to high 13's dead stock.
also A4 vettes have the same problem as FBody's do. weak rears Dana 36's can hold from 11.8's to 13.0 and let out anywhere between there. i wouldn't recommend a lower gear due to the fact the pinion has more bite on the ring gear.
Easy mods to do:
FULL tuneup w/ AC Delco Rapid fire plugs, TB Bypass, Cut lid w/ K&N filter, descreen the MAF unit, 1.6 RR's, muffler eliminator's, pulley set, LT headers, (factory manifolds are very similar to shorty headers and there are companies such as http://tpis.com that make good fit LT headers for these cars. shorties are a waste of $) and LT1 edit.
with these mods it will probably run mid to high 12's pretty easy. if you plan to run DR's don't do a stall unless you want to break things. i pull 1.80 60' times in my 87 TPI vette with stock 1600 stall and 2.59 rear gears. his is probably 2.59's or 3.07's. write down the RPO codes either under the center console lid or under the back 2 lids behind the seats then match them up at
http://www.corvetteactioncenter.com/...94/94prod.html
hope this helps
Old Apr 6, 2004 | 12:24 PM
Vendetta's Avatar
Originally Posted by Mad-Mic
sup fella's.
check out
Easy mods to do:
hope this helps
Cool man you should stick around, we could use more vette guys in our LT1 forum.
Old Apr 6, 2004 | 12:43 PM
Half Fast's Avatar
lot's of good info at www.corvetteforum.com , and I know a little bit about them too.
Old Apr 6, 2004 | 04:50 PM
TSAEB's Avatar
Man I think I learned more about my lil cousins car after reading all this (plus the websites) then my car… kind of disappointed though about the weak rear end…oh well he’ll have much more fun with a 12bolt…oh my cus says he wants to change the auto for a manual…what do you all think of the conversion…I hear for racing auto is better…no miss shifts…but I have a hell of fun with my m6 on my z.
Old Apr 6, 2004 | 06:36 PM
Half Fast's Avatar
My vette's an auto. I swapped in a Dana 44 rear out of a 6 speed car with the 3.45 gear. It's run a best of 11.5 @ 121 on a 100 shot + the N/A mods. 2nd stage numbers coming soon.
I've got a complete dana 36 with 3.07's if any one is looking for one.
Old Apr 6, 2004 | 08:33 PM
TSAEB's Avatar
bad news... I check the car and its not a 94 it looks like a 91...so how much of the info ya guys have said actually changes...the disributor is on top and it has a different type of itake....so i have to start reading again...
Old Apr 6, 2004 | 08:39 PM
it's not an LT-1 if its a 91. Most likely an L98. It's a classic smallblock.
Old Apr 6, 2004 | 09:31 PM
Vendetta's Avatar
Yep it's an L98. Does it have intake runners?
No worries though, L98s can be pretty good motors if you can get them breathing well up top. My friend had two L98s, one was in 12s, the other in 13s. Best possible thing he can do is swap the TPI intake manifold and runners for either an LT1 intake, or some other kind of aftermarket intake. When I was first looking at buying a car I really wanted an L98 Vette.
Other than that, there are tons of cams available, just as many as there are for the LT1. Definitely want to swap out the heads as well, they're very restrictive. Good luck.
I'm going to try to get my friend to post in here and give you some suggestions.
Old Apr 6, 2004 | 10:12 PM
TSAEB's Avatar
ok so if the lt1 intake bolts on do the heads fit also?
