Car suddenly dies...
Old Aug 15, 2012 | 07:20 PM
xxRONNIExx's Avatar
Default Car suddenly dies...
I was driving my car today (1994 z28) and it suddenly shut down. No power at all. This has never happened before. Once I got to the side of the road I let it sit for a little while, the car cranks and wants to start but couldn't. After about 10 minutes it would start, I'd drive for a few minutes and it would die again.
Did this all the way home. Need a little help...thx
Old Aug 16, 2012 | 02:54 AM
goldylocks's Avatar
My best bet is the ICM as I've seen them cause this sort of failure before. You could try spacing the icm/coil off the head with a couple of washers so prevent it from getting too hot as this is generally the cause of their failure
Old Aug 16, 2012 | 03:26 PM
ahritchie's Avatar
^ What he said...common issue on these cars
Old Aug 16, 2012 | 05:53 PM
warriorcustoms's Avatar
The proper fix would be to take it apart & use Dielectric grease on all the mating surfaces Same with any new ICM
Old Aug 19, 2012 | 09:46 PM
xxRONNIExx's Avatar
Sorry for the late response guys..I replace the ICM and its still shutting off after about 10 minutes. Its cranking and wants to start but doesn't. After I wait for awhile it will start up then die shortly after...Im baffled
Old Aug 19, 2012 | 09:48 PM
xxRONNIExx's Avatar
I also put in a couple washers along with dielectric grease when I installed it.
Old Aug 21, 2012 | 01:47 PM
ahritchie's Avatar
FWIW, my MSD coil took a **** the same time my ICM went out So, you may want to try a $20 autozone special replacement coil too.
Old Aug 21, 2012 | 11:33 PM
xxRONNIExx's Avatar
Yeah when I had everything out I should have replaced it as well. I'll replace the coil and see how it goes, thanks
