93 lt1 timing chain
Old Aug 26, 2012 | 03:14 PM
turtle93's Avatar
Default 93 lt1 timing chain
Ok dose anyone sell an up graded for the time chain on a 93 that dosent require swapping 1400 bucks and do I need it I'm only spining to 5800 rpms with a 100 shots
Old Aug 26, 2012 | 03:24 PM
guppymech's Avatar
The OEM GM timing set is the best set out there for the spline drive opti. Use it with a oversize Cloyes crank gear if you want the chain tighter than GM sets it.
Old Aug 26, 2012 | 04:44 PM
TwoFast4Lv's Avatar
Lunati is the only one I have found a 92-94 version of the LT4 Extreme
