which lifters to run?
Old Sep 10, 2012 | 02:45 PM
95mysticta's Avatar
Well my noisey valvetrain issue is fixed and not the lifters fault this time. Narrowed the intermittent tick to the #5 spring area so we pulled the springs had them checked and they were fine but noticed that the guideplates were riding and the pushrods were seeing some wear more then others. Grinded it down and the ticking is now gone! Dont know if that was the issue or not but im just happier its not worse! Put 600+ on it this weekend and havent had an issue yet! Keep you posted on how these new LS7s hold up.
Old Sep 10, 2012 | 03:27 PM
96capricemgr's Avatar
What guideplates?
I see you have AFRs were they AFR spec guideplates, do those heads have non-stock valvespacing?
The LT1 stock spacing is a little different than older sbc engines which leads to people using a lot of poorly fitting guideplates.
Old Sep 10, 2012 | 05:51 PM
trilkb's Avatar
Originally Posted by SAPPER
GM SI states that preload is 270* (3/4 turn). But anything warranty or repair now is LSx motors. So no preload on shaft mount rockers. And yes, usually only the bad ones are replaced but sometimes all will get replaced based on the inspection.
I got the original Delphi lifters from Skip White. These are GM's NOS (new old stock).
I dont run shaft mount rockers, is it also a myth that less pre load is better for aggressive cams?
Old Sep 10, 2012 | 05:57 PM
SS RRR's Avatar
Village Troll
Originally Posted by Wicked94Z
Wait... so you're saying if the valvetrain stays in control, 60psi oil pressure won't overcome 350 lbs of valvespring?? How could that ever be
I've got some for sale. The newer style/weaker retainer that were used for a GM847, turned to 6500rpm with a spring in the 400lb range. They're in great condition. You want them? The only catch is to stay away from bert bowerz HR camshafts.
Old Sep 10, 2012 | 06:21 PM
trilkb's Avatar
^ what?
Old Sep 11, 2012 | 03:52 PM
95mysticta's Avatar
Originally Posted by 96capricemgr
What guideplates?
I got these heads used and they didnt come with guideplates. Im running the Isky adjustable ones.
