yet another 24x question, but different c100
Old Sep 6, 2012 | 09:00 PM
daddyoisback's Avatar
Default yet another 24x question, but different c100
ok my question is about the C connectors. c100 c105 c210 c220 c230
I have a 2002 rs are this connectors the same or do i have to hunt down a new chart for the o2'?
Old Sep 6, 2012 | 09:34 PM
shbox's Avatar
I'd say you need a 2002 wiring diagram to confirm.
Old Sep 6, 2012 | 10:44 PM
green96ta's Avatar
are you trying to re-wire your harness for the 24x conversion? Because if so, your 2000 diagrams for those connectors will be useless....
If you need help with the re-wire pm me and Ill help you out.
Old Sep 7, 2012 | 05:14 PM
i should have been more clear, it was late sorry. yes doing a re-pinn .I have the diy kit from mike, and a 0411 comp with a 97' LT1 harness, but my question is about the c connectors cause my car is a 2002 if that clears it up
Old Sep 8, 2012 | 06:04 PM
merim123's Avatar
all you need in the c100 from your 02 is positive 12 volts going back to the fusebox. You'll need a few for your ignition coils, fuel injectors, PCM switched and unswitched 12V. so, just figure out which one's are hot and use those for your 97 harness.
Old Sep 8, 2012 | 07:34 PM
ok havnt got that far yet. have all four lt1 plugs empty. got to go threw and delete wires that i'm not useing and double check everything. then it's on to the C connectors.
