What was the LT-5 rated at from the factory
Old Apr 7, 2004 | 02:47 PM
ZL1camaro's Avatar
Default What was the LT-5 rated at from the factory
Old Apr 7, 2004 | 03:03 PM
Half Fast's Avatar
YEARS 1990-92 1993-1995
SAE Net Power 375 hp @ 6,000 rpm 405 hp @ 5,800 rpm
SAE Net Torque 370 ft lbs @ 4800 rpm 385 ft lbs @ 4800 rpm
Compression Ratio 11:1 Same
Bore/Stroke 99 x 93 mm (3.90 in. x 3.66 in.) Same
Firing Order 1,8,4,3,6,5,7,2 Same
Bore/Stroke Ratio 1.07:1 Same
