fuel injectors
Old Sep 20, 2012 | 07:31 AM
BallerCamaro21's Avatar
Default fuel injectors
i have a 96 trans am with a comp cam 503 in it and long tube headers and flow master exhaust. i am getting the heads and intake ported and polish and a 52 mm throttle body put on. my question is what size injector should i run with my set up?
Old Sep 20, 2012 | 08:30 AM
RamAir95TA's Avatar
30# injectors will be fine.
Truthfully though if you're only using a 503 the stock 24# will suffice too.
Old Sep 20, 2012 | 05:37 PM
great421's Avatar
He could probably pic up some stock LS injectors (28 lbs vs. LT's 24lbs) for a very reasonable price from someone going FI too...
Old Sep 20, 2012 | 06:26 PM
RamAir95TA's Avatar
Sure he could, but there would be absolutely no benefit and a simple wasted expense.
