Car turns off while running please help!
Old Oct 28, 2012 | 12:01 AM
Mar0z28's Avatar
Default Car turns off while running please help!
1st off the cars a 93 lt1 a4
A few months ago the car went down and i replaced the fuel pump,fuel filter,opti,icm,coil,wires,plugs.And the cars been running good til a couple weeks ago.
Now the car while running just turns off either at low speeds,high,or idle.Doesnt really make a noise just shuts off. sometimes it starts right back up and then sometimes it takes awhile.
I thought it might be the icm so i replaced it with warranty. then i replaced the fuel regulator and nothing.
Any info will be much appreciated!!
Old Oct 28, 2012 | 02:09 AM
383whitez's Avatar
I have a 94 trans am that would shut off around 180 degrees every time and would sometimes start up after awhile but sometimes not. Sometimes it would not start even if cold, it ended up being the opti even though it was changed 6 months prior. We thought icm as well but unfortunately no dice so maybe look into the opti.
Old Oct 28, 2012 | 02:58 AM
Rob94hawk's Avatar
IMO it's the opti. Only the opti can pull off that sort of crap. With no codes too!
Old Oct 28, 2012 | 10:01 AM
Mar0z28's Avatar
Ahhhhhh 383whitez and rob94hawk i had a feeling it was that but i was hoping for somthing else. yea i changed it 7mos ago. thanks alot for your input
