Wolfe Racecraft
Old Nov 2, 2012 | 11:29 PM
TexasNative's Avatar
Originally Posted by fex77k
I worked on them, never got to fly in one. Some of my coworkers did. My doorslammer is quick enough.
Not to stray from the topic of the post but you got a leg up on me. Closest I ever got to them was pulling guard duty on the HARM munitions
! Didn't those replace the raven or something like that. I recall,seeing another model of counter e-warfares out there in Desert Storm but I believe they were operated by the AF.
Old Nov 2, 2012 | 11:52 PM
fex77k's Avatar
The EF 111 was decommissioned, the navy flew the Prowlers amd recently began moving to the growler an 18 conversion.
Old Nov 2, 2012 | 11:58 PM
96silverram's Avatar
+3 for the Wolfe 6 point CM(jig notch, bolt-in, and swing-outs)
Old Nov 4, 2012 | 01:18 PM
robsquikz28's Avatar
Cm bolt in is very costly especially for the 25 lbs lightening over MS but i guess when u have a 25.5 cage its worth the extra coin and weight savings.
For the average car MS is perfect. Also u can get some shops to install CM weld ins for just a tad over a stack. That will be worth it IMO. Either way 750 for a bolt in is still costly
Old Nov 4, 2012 | 05:09 PM
fex77k's Avatar
They really stick it to you for CM now days. It's hard to find anyone that has a local stock. You have to order them in quantity to save money, but you get hit on shipping for the lengths.
Old Nov 4, 2012 | 05:32 PM
Shownomercy's Avatar
Man-Crush Warning
Any thoughts on MWC bars?
Old Nov 4, 2012 | 06:46 PM
Boosted Firehawk's Avatar
I can get the CM weld in for about 450 but then you need to have someone weld it in
Old Nov 4, 2012 | 11:27 PM
If I didn't have a TIG setup and wasn't good with welding CM I def would've gone with MS and had it welded in for the cost savings. Doesn't matter too much to me. As long as it's safe and I can pass tech inspection at the track is all that's important as far as i'm concerned.
