Help - no spark LT1, extensive testing...
I'm about at my wits end with a 95 LT1 that wont spark! Long story short the engine was swapped into a Porsche 944 and I received the car not running. My initial thought was the Opti, so I bought a cheap one off ebay (which I have since learned is a bad idea). After installing, I still get no spark, so I followed this guide:
http://www.mainstreamtopics.com/foru...rt-diagnostic/
I got down to the step where it says to test for a pulsing ground at the white/black wire on the coil, from the ICM. With the key on, engine off, I have a ground, but it is not pulsing. Just stays consistent green. per the instructions, I ran out and got a new ICM, only to replicate the same situation.
Since that did not fix it, I also thought the coil might be bad - so I replaced that, which only resulted in a very weak positive signal coming out of the coil with key on, engine off. Still no spark, and no increase in signal when turning the engine over (testing at the coil).
So, does anyone have additional insight about something I might be overlooking here? I really dont want to buy a new Opti if I dont have too, but with a new ICM and coil, I can't think of anything else. And with the injectors pulsing and the proper voltage going into the Opti, I'm worried I'll just burn more money by replacing the Opti again.
Thanks in advance, any help is much appreciated.
Also Im sorry to say but its very possible you got a bad opti, they rebuild old ones and the optical sensors are cheap ones. But one way to check is take your opti off, plug it in, and turn the KOEO, and turn the opti rotor,you will be able to hear the coil and injectors are pulsing.
Also could be your PCM, but not very likely, check ALL of your grounds. Especially since its a non-running swap they could have over lookid those,. Harness grounds are located on the ICM, behind the pass. cylinder head, and starter. I might be missing one but make sure all of those grounds have continuity.
Sorry to say but it sounds like the opti is a cheapo. But no need to bite the bullet and get a new one yet, do some testing and let us know what you come up with.
so, it took 4 autozones but i finally found one that had the right connector to actually test the ICM. Unfortunately both ICM's passed the test numerous times....so the only thing left to replace is the opti correct?
Is it possible that the opti could only be partially working which would cause the injectors to pulse but not get spark?
At this point my fingers are crossed that it's just the opti...a new ECU + the programming to make it work with the 944 is not something I can afford for a while.
