94 z28 needs help
Mods includ
4:10 rear
MSD coil
Hypertech P3
JET piggy back stage ll
K&N air filter
Pro50 shifter
underdrive pullys
Note I have pulled all the mods but gears and pullys for testing on scanner
PLEASE help any suggestions are greatly welcomed
thanks
Are you running an HPP and a Jet at the same time?
I also run a hollow cat with flowmaster cat-back
My car ran great for a while and then progressivly got worse. Tried several things to see why it ran like crap. Had the cat pulled and it was really plugged.
Car goes GREAT now.
Ron
No, but pull the fuse on the PCM or disconnect your battery for at least 20 minutes to reset the PCM and put it back into learn mode.
Car could also be running "too" cold. You want about a 180 coolant temp. once it's warmed up. Use a scan tool as the factory gauge is inaccurate. I have a '94 as well. You could be sticking in the cold start enrichment mode if you don't allow the coolant temp to get warm enough.
http://www.akmcables.com - my web site
I wouldn't run both Jet and HPP at the same time. Either / or, but not both. Of course, my real opinion of both of them...
A PCM reset happens after a second or two. No need to wait 20 minutes. On a 94Z, it's the PCM BAT fuse that's in the driver's side of the dash, just inside the door. I believe it's one of the lower right fuses. Back in the way-early days of LT1Edit (almost 5 years ago), anytime I read or programmed my PCM, I had to reset the PCM by pulling the fuse.
