Steam Pipe
Old Dec 26, 2012 | 06:34 PM
Evaporate's Avatar
Default Steam Pipe
When installing the steam pipe for the reverse flow cooling on the back of the heads, should I use thread sealant? And how about rtv to seal the washer to the head, any required or should it go on bare?
Old Dec 26, 2012 | 07:34 PM
guppymech's Avatar
The factory sealing washers with the rubber insert seal the steampipe banjo fitting to the cyl head and to the large washer head on the bolt. I would stay away from using RTV on the steampipe or the bolts, if some RTV extruded into the steam pipe or hollow bolt it could clog it up. I would use anti-seize on the steampipe bolts, if antifreeze leaks up the bolt threads it will be trapped by the sealing washers, no pipe sealant required.
Old Dec 26, 2012 | 07:39 PM
Evaporate's Avatar
Thanks for the good info
Old Dec 28, 2012 | 10:35 AM
BALLSS's Avatar
and it is 2 washer per side. one on each side of the steam pipe per cyl head.
don't use RTV
