LT1 fuel split
Update:
I installed my facotory TB on it and the fuel split went from:
B1 +49.9(max on gauage)
B2 -17.x to -24.x
After stock TB:
B1 +49.9
B2 +32.x(cold) +5.x to +15.x(warm)
So I've still got a split, but it isn't a lean/rich split. Just Lean/not as lean lol
Ohm'd all plug wires. Two had high resistance.
Replaced wires. ALONG with new plugs gapped to .35
Was told to inspect my MAF. It was a bit dirty, so I cleaned it. No change.
I took Ed's recommendation on using Factory metal MAF ends rather than my ported ends.
Installed them, NO change.
So complete run down-
FACTORY MAF
FACTORY THROTTLE BODY
NEW spark plugs gapped .35
NEW header gaskets
Checked for other exhaust leaks--NONE
SWAPPED injector sides
SWAPPED O2 sides
NEW O2's
Inspected O2 EXTENTIONS. LOOKED OK with no burns(will ohm wires if recommended)
Tuner & I played with tune this evening.
Added fuel several times(at one point up to 8% more) and it FIANALLY got B2 where it should be. But adding fuel seem to make the split worse bc B1 was stay at 51%(lean)
B1 WILL NOT COME DOWN.
I am LOST....
Fuel split fixed.
Thx for all the help along the way.
