Stock long block cam
I was hoping she didnt have the 5.0!
Already have the ball rolling with bolt on's(pacesetter LT's, 58mm TB, 160 stat, K&N CAI) I was thinking for the cam high 220's maybe low 230's for intake and ex with a 1.6 rr, beehive springs?! I was thinking in the GM847 area.
How well do these perform with a large cam on a stock long block?
Can I trust the stock short block past 6500+rpm with ARP's?
The cc503 is what I would recommend. Hands down its the best self cam for a lt stock long block.
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
ARP fasteners are not magic bullets; they just make sense when you rebuild the bottom end. With a good rebuild, you'd be good for 7000 rpm.
I wouldn't want to put up with the 847 cam with an automatic car. Too big.
Which year T56? If tyhe later one with the .50 OD then you really shoul;d be considering 4.10s especially if you are of the "bigger is better" camp of cam selection. I know that sounds like a lot of gear but I thnk it was the 94+ T56 was .50 OD that soaks up 4.10s wonderfully. The .50 OD with the T56 makes it comparable to a 4L60E with 2.93 gears. Now strictly comparing top gear cruise rpm.
NOBODY is going to tell you 2.93s are right for a A4 most will say 3.73s for an A4 which would be like a 5.22 with the .50 OD. Now that kind of gear would make first useless and be weak with a tiny pinion so I am not suggesting such a thing, just trying to make a point about how 4.10s are pretty mild when behind a double OD with top being .50.
I would do custom on a tighter LSA unless tailpipe testing is a concern which seems doubtful.
http://advancedinduction.com/LTX/AiLTxCamKit.php
The 230/238 110lsa would probably suit you since you want big.
You can buy the cam separate but if you actually tally up everything included there the price is competitive if you want to use all very good components like that. You could "save" some money buying cheaper components but in my experience cheaper components don't grow with your setup as you keep modding so you replace them sooner and they cost a lot more in the longrun even if they don't break.
